The WiiM Amp is designed to be on as long as it remains connected to a power source. However, for energy efficiency or other reasons, you may not want it always to be active. If you want to manage the power state of your WiiM Amp, you can do so in the following ways:
1. Using Standby Mode:
- You can set the WiiM Amp to go into a low-power standby mode after a period of inactivity. To do this, go to the ‘Device’ tab in the WiiM Home app.
- Tap on the ‘Gear’ icon to access settings.
- Select ‘Standby Mode’ and then ‘Set Standby Time’ to choose how long the Amp will remain inactive before entering standby mode.
2. Manual Power Off:
- If you prefer, you can manually disconnect the WiiM Amp from its power source to turn it off. This is a simple method if you don't need the Amp to be in a ready-to-use state.
