The firmware update is performed in batches such that the devices take turns getting updated. All the devices will be updated during the next few days.
Please find the list of known issues here that we're working around the clock to fix and release a solution by the ETA.
Please note the device firmware version is different from the version of the WiiM Home App. You can check your device's firmware version on the WiiM Home App. Please select the Device tab > Tap the device setting gear icon (i.e., the Cog Wheel) > Speaker Info > Firmware Version.
4.8.614042 (Latest)
Release date:
     4 / 16 / 2024
What's New:
  1. Per-Source EQ (App version 2.9.0+ required): Customize EQ settings for each input source individually.
  2. Faster Optical Detection: Quicker detection of audio from Optical inputs.
  3. Enhanced DHCP Stability: Upgraded DHCP service for improved network stability and connectivity.
Bug Fixes:
  1. Track Metadata XML Fix: Resolved an issue with missing xmlns:song namespace in Track Metadata XML for better metadata management.
  2. AAC/ALAC Bitrate Display Fix: Accurately displays the correct bitrate for AAC and ALAC formats.
  3. Remote Pairing Stability: Improved the pairing process of the WiiM Voice Remote for more reliable connectivity.
4.8.612733
Release date:
     4 / 3 / 2024
What's New:
  1. Soundtrack SDK Enhanced: We've upgraded the Soundtrack SDK to improve your listening experience.
Bug Fixes:
  1. Resolved Pandora Crash Issue: The issue causing Pandora to crash has been fixed, ensuring uninterrupted listening
4.8.612257
Release date:
     3 / 28 / 2024
Bug Fixes:
  1. Pandora Stability: Fixed the issue with Pandora for a smoother listening experience.
  2. AirPlay Fade-in/Fade-out: Fixed the Fade-in and Fade-out settings for AirPlay streaming.
  3. Remote Pairing Stability: Enhanced the WiiM Voice Remote's pairing process for a more reliable connection.
4.8.611137
Release date:
     3 / 18 / 2024
Bug Fixes:
  1. 12V Trigger Output Stability: Fixed a bug that ensures the 12V Trigger stays active with the device, eliminating accidental shutdowns.
  2. Bluetooth Playback Improvement: Addressed and resolved stuttering during playback with certain Bluetooth headphones and earphones, providing a seamless audio experience.
  3. Preset Management Enhancement: Corrected an issue that prevented preset replacement, enhancing the feature's reliability and user experience.
4.8.609154
Release date:
     2 / 29 / 2024
What's New:
  1. Custom Radio Metadata: Now with dynamic track information, compatible with our latest app.
  2. Soundtrack Your Brand Integration: Transform your business ambiance with Soundtrack Your Brand. Gain legal access to an unparalleled commercial music catalog boasting over 100 million songs, designed to enrich your commercial space effortlessly.
  3. New Wi-Fi Disconnection Indicator: The device status light now glows yellow to signal Wi-Fi disconnection, replacing the previous solid red indicator.
  4. Improved 12V Trigger Output:
    • Standby Mode Synchronization: The 12V Trigger now reflects the device’s Standby status, activating with device use and deactivating in idle mode.
    • Improved Standby Efficiency: For devices set to remain always on, the 12V Trigger will now automatically shut off after 5 minutes of inactivity, enhancing energy efficiency.
4.8.606452
Release date:
     2 / 2 / 2024
What's New:
  1. 12V Trigger Out Enhancement: The trigger will now turn on or off immediately when the power is switched on or off via the Remote. Additionally, it will automatically shut off after 5 minutes if the device is inactive.
Bug Fixes:
  1. Improved Remote Connection Stability: Enhanced the stability of the connection between the WiiM Voice Remote and your WiiM device.
  2. TIDAL Connect Stability: Resolved unexpected crashes when using TIDAL Connect, ensuring a more reliable streaming experience.
4.8.605651
Release date:
     1 / 25 / 2024
What's New:
  1. Per-Source Volume Control: Introducing individual volume control with memory for Optical In, Line In, Wi-Fi, and Ethernet input sources, allowing for a tailored listening experience on your device. (Compatible with the upcoming app update in a few days.
Bug Fixes:
  1. Stabilized Wi-Fi Connection: Addressed and fixed a Wi-Fi exception issue, significantly enhancing Wi-Fi stability.
  2. Continuous Volume Increase Issue Resolved: Corrected a problem where volume would continuously increase when using Spotify Connect.
  3. LMS Playback Distortion Resolved: Addressed and corrected the distortion issue encountered during playback through the Logitech Media Server (LMS).
  4. Multi-Room Audio Stabilization for Line-in: Fixed the stuttering issue observed in multi-room audio playback when using the Line-in input source.
  5. Enhanced Playback Status Accuracy: Resolved a problem in the WiiM Home app to accurately display the playback status when switching to Line-in or Optical-in input sources.
4.8.604351
Release date:
     1 / 11 / 2024
What's New:
  1. Enhanced Volume Balance (Compatible with the Latest App): We've introduced a Volume Balance feature, allowing you to fine-tune the audio levels between the left and right channels for a more personalized listening experience.
  2. Optimized Wi-Fi Connectivity with Mesh Network: Enjoy uninterrupted connectivity as your device intelligently selects the strongest Wi-Fi access point, ensuring a stable and robust connection.
  3. Qobuz Autoplay Integration: When your music queue ends, Qobuz takes over by playing similar tracks, keeping the music flowing without interruption.
  4. AirPlay Cast Experience Enhancement: Supporting that you can use AirPlay Cast to cast audio from your device to HomePod Stereo; also, we have improved playback synchronization with HomePod Stereo.
Bug Fixes:
  1. Resolved AirPlay Cast Playback Issue: We've fixed the issue where high-quality audio (176kHz or 192kHz) and line-in inputs were stuttering when played through AirPlay Cast. Now, your audio should play smoothly.
  2. Remote Mute Functionality for AirPlay Cast: Muting audio through AirPlay Cast is now fully functional, offering you more control.
  3. Stabilized Wi-Fi Connection: Addressed and fixed a Wi-Fi exception issue, significantly enhancing Wi-Fi stability.
  4. General Enhancements: Various other bug fixes and performance improvements for a smoother experience.
4.8.605451
Release date:
     1 / 25 / 2024
What's New:
  1. Per-Source Volume Control: Introducing individual volume control with memory for each input source, allowing for a tailored listening experience on your device.
Bug Fixes:
4.8.537951
Release date:
     12 / 21 / 2023
What's New:
  1. Roon Ready Certification: WiiM Pro Plus is now officially Roon Ready Certified, offering an enhanced audio experience through superior integration and performance.
    Important: If the WiiM Pro Plus doesn't appear under 'Roon Ready' in the Roon app, restart the app to ensure it displays correctly.
  2. SPDIF Input Enhancement: Upgraded our SPDIF input with an advanced anti-drift mechanism and a refined resampling algorithm, ensuring smoother and more stable playback.
Bug Fixes:
  1. TIDAL Connect Stability: Resolved unexpected crashes when using TIDAL Connect, ensuring a more reliable streaming experience.
  2. Spotify Connect Stability: Fixed the unresponsiveness issue in Spotify Connect for a smoother user experience.
  3. Deezer Playback Improvement: Implemented a feature to automatically skip to the next track if the current one is unavailable, maintaining a seamless listening flow.
  4. Volume Adjustment Stability: Fixed a crash issue related to volume adjustment, enhancing overall system stability.
  5. Enhanced Squeezelite Playback Stability: Fixed intermittent popping sounds after track seeking, improving playback quality.
  6. General Enhancements: Various other bug fixes and performance improvements for a smoother experience.
4.8.537951
Release date:
     12 / 07 / 2023
What's New:
  1. Distinct Status Light Indicators for Input Sources:
            • Optical-in sources now display an orange light.
            • Line-in sources are indicated with a light green light.
            • Bluetooth sources are represented by a pure green light.
Bug Fixes:
  1. Enhanced EQ Experience: Resolved an issue where playback would stop when switching between PEQ (Parametric EQ) and GEQ (Graphic EQ). Reduced CPU usage during EQ operations for more efficient performance.
  2. TIDAL Connect Stability Enhancements: Addressed and fixed unexpected crashes when using TIDAL Connect, ensuring a more reliable streaming experience.
  3. Calm Radio Login Fix: Resolved an issue preventing login to Calm Radio accounts containing the "$" character.
  4. Chromecast Playback Control with Spotify: Fixed an issue where playback controls were unresponsive when streaming Spotify via Chromecast.
4.8.537051
Release date:
     11 / 29 / 2023
What's New:
  1. TIDAL Hi-Res FLAC in WiiM Home App: We've introduced TIDAL Hi-Res FLAC support, allowing you to stream directly up to 24-bit/192kHz.
  2. Napster API Upgrade: We've updated to the latest Napster API for enhanced and more reliable streaming.
Bug Fixes:
  1. TuneIn Custom URL Preset Issue Resolved: Fixed the issue with TuneIn Custom URL presets.
  2. Bluetooth Streaming Reliability: Addressed occasional crashes during Bluetooth streaming.
  3. General Enhancements: Various other bug fixes and performance improvements for a smoother experience.
4.8.536232
Release date:
     11 / 20 / 2023
Bug Fixes:
  1. Enhanced Remote Pairing Stability: Improved the pairing stability of the WiiM Voice Remote, ensuring a more reliable and seamless connection experience.
  2. TIDAL Connect Stability Improvements: Fixed problems with TIDAL Connect, including unplayable tracks and unexpected crashes, for a smoother streaming experience.
  3. Spotify Connect Playback Optimization: Resolved the brief silence encountered during the first half-second of song playback on Spotify Connect, ensuring uninterrupted audio from the very start of each track.
4.8.534065
Release date:
     10 / 29 / 2023
What's New:
  1. TIDAL Hi-Res FLAC Support: Introducing support for TIDAL Hi-Res FLAC via TIDAL Connect, enabling direct streaming up to 24-bit/192kHz from TIDAL App.
  2. Spotify Connect Upgrade: Transitioned to the latest Spotify Connect ESDK for an enhanced user experience.
Bug Fixes:
  1. Service Access: Resolve a rare issue where incorrect system time settings prevented users from accessing services.
  2. Other bug fixes and performance improvements.
4.8.532839
Release date:
    10 / 18 / 2023
What's New:
  1. Enhanced Amazon Music HD Streaming: Memory optimization now allows for smoother 24-bit/192kHz audio streaming on Amazon Music HD.
  2. Upgraded Audio on WiiM Pro Plus: Experience even better sound with improved THD+N performance for 176kHz and 192kHz audio via optical input.
Bug Fixes:
  1. TuneIn Radio Playback: Resolved issues that were blocking playback on select TuneIn radio stations.
  2. WiiM Voice Remote Pairing: Fixed intermittent pairing issues with the WiiM Voice Remote for a more reliable connection.
  3. Bluetooth EQ Settings: Corrected EQ settings for enhanced audio output in Bluetooth mode.
4.8.530553
Release date:
    9 / 26 / 2023
What’s New:
  1. Improved in-App Deezer experience: Deezer update with new API and functions. Please re-login to Deezer via the WiiM Home app.
  2. Optical Input Boost: Now enjoy multi-room audio over 48 kHz/16-bit on optical input.
Bug Fixes:
  1. Enhanced EQ Stability: Maintain Line-in or Optical-in input when switching between PEQ and GEQ.
  2. Enhanced Stability: Fix occasional crashes during volume adjustment.
  3. Alexa TTS: Fix noise distortion in Alexa TTS when using BT source mode.
  4. Radio Paradise Artwork on Squeezelite: Fix artwork display for the Radio Paradise on Squeezelite.
  5. Roon on Squeezelite: Fix the silence when casting audio via Squeezelite.
  6. Play Queue – Corrected track ordering when adding multiple Amazon albums.
  7. TIDAL Access: Resolved issues with third-party authentication for TIDAL access.
4.8.529057
Release date:
    9 / 11 / 2023
This update includes:
  • New Feature - Parametric EQ (Compatible with App version 2.5.5 or higher)
  • New Feature – Choose DAC‘s digital filter type (Compatible with the new app updated in a few days)
  • Fixed – DHCP improvement for IPv6 on certain routers
  • Fixed - Unable to pair with the WiiM Remote occasionally
  • Fixed - Multi-room audio for Line-in input of more than 48kHz input
  • Fixed - Qobuz shuffle play
  • Fixed - Occasional crash with Roon Ready
  • Fixed - No metadata with AirPlay and Amazon Music in certain use cases
  • Fixed - Unable to control playback and volume for Squeezelite when the IP address of LMS changed
  • Other bug fixes and performance improvements
4.8.526344
Release date:
    8 / 14 / 2023
  • New Feature - AirPlay Cast (Compatible with App version 2.5.5 or higher)
  • New Feature - Volume limit (Compatible with the new App to be updated in a few days)
  • New Feature - Add entire album/playlist to the play queue for TIDAL (Compatible with the new app updated in a few days)
  • Fixed - Occasional failure to stop Amazon Alexa multi-room playback
  • Fixed - Pop noise with Amazon Alexa multi-room
  • Fixed - Occasional crash issues for AirPlay and Roon Ready
  • Fixed – Fade-in/fade-out off
  • Fixed - Incorrect playback order with the large Qobuz play queue
