How to turn on “5 GHz Only” to improve device discovery and more smooth audio playback?
Modified on Tue, 19 Jul 2022 at 07:29 PM
The advantage of 5 GHz is that it has a higher transfer speed and it's less vulnerable to wireless interference
First, please make sure your Wi-Fi router supports 5 GHz band. Then follow these steps to turn on 5 GHz Only on the WiiM Mini with WiiM App:
1. Open WiiM Home app.
2. Go to Device tab -> Tap device setting gear icon -> Wi-Fi status.
3. Turn on 5 GHz Only.
Note:
1. When turning on "5 GHz Only", your device will disconnect from your Wi-Fi router then reconnect if it previously connected to 2.4 GHz band with the same wireless network name. The reconnection process takes about 2 mins. If the device is already connected to 5 Ghz band, it'll ensure the device will connect to 5 GHz band only when roaming or device rebooting.
2. If your device doesn't reconnect with your Wi-Fi router successfully, please reset your device to the factory settings and set it up again with the WiiM Home app.
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Let us know how can we improve this article!
Select atleast one of the reasons
Feedback sent
We appreciate your effort and will try to fix the article
