1. Add Your Favorite Music Services
  • Open WiiM Home App.
  • Tab Browse "" at the bottom.
  • Select your favorite music services and sign in with the corresponding account.
  • Tap "Manage Music Services" to see more services.
2. Rename WiiM
  • Tab Device "" at the bottom.
  • Tap "" on your device and select Rename.
  • Choose or fill in your desired name.
  • Tap the Finish button to save on the upper right corner of the screen.
3. Switch Audio Source(Wi-Fi/Aux-In/Bluetooth)
  • Scroll down and select a source in “Select source on device”
4. Sleep Timer Setup
  • Enter Now Playing screen and tap "" the button
  • Select Sleep Timer and choose the time
5. Act as a Bluetooth speaker
  • Press and hold the +&- for 3s on your WiiM Mini or switch the BT audio source in WiiM Home App.
  • Open Bluetooth settings on your computer, mobile device, and more.
  • Scan the Bluetooth devices nearby.
  • Select the device with the name WiiM Mini_xxxx to pair.
6. Restore factory settings
  • Press and hold the "” on your WiiM Mini
  • Open WiiM Home app.
  • Tap Device "" at the bottom.
  • Tap "" on your device and select Speaker Info.
  • Tap Restore Factory Settings and Confirm this operation.
7. Volume Limit
  • Tap "" on your device and select Volume Limit.
