Logo
Help Center
Welcome
Login  Sign up
Home Solutions
New support ticket
Check ticket status
Solution home Advanced Troubleshooting Router Issues
FRITZ!Box Router - Discovery and Connection Issues Print
Modified on: Mon, Nov 28, 2022 at 11:58 PM
In the Fritzbox router, within the ‘WiFi security’ tab, there is a setting called The WLAN devices displayed may communicate with each other → enable it, if it is disabled.
WiiM require unrestricted internet access. If you have assigned any restrictions undo it.
https://en.avm.de/service/knowledge-base/dok/FRITZ-Box-7530/8_Restricting-internet-use-with-parental-controls/
Did you find it helpful? Yes No
Send feedback
Sorry we couldn't be helpful. Help us improve this article with your feedback.
Related Articles
    Home Solutions
    Article views count
