Why am I getting less than 1411kbps (generally 500-900 kbps)? signal strength is “very good” and i’m using tidal hifi…
Modified on Tue, 20 Sep 2022 at 02:27 PM
What you received from TIDAL is the losslessly compressed FLAC file, it'll be decoded into 44.1k/16-bit PCM then played. The bitrate of the encoded FLAC is varied between 450kbps to 850kbps as you observed from the App. The decoded PCM is 1411kbps as you stated.
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Let us know how can we improve this article!
Select atleast one of the reasons
Feedback sent
We appreciate your effort and will try to fix the article
