What is the maximum bit and sample rate from the optical SPDIF output?
Modified on Tue, 07 Jun 2022 at 06:00 PM
WiiM Mini can decode the 192 kHz, 24-bit lossless music files or streaming contents. When WiiM Mini supports bit-perfect function via digital optical output, it outputs the same bit depth and sample rate as your music source. I.e., if your source is 24 bit/192kHz, it will output 24/192. While if your source is 16-bit/48kHz, it outputs the same without upconversion. It uses the sample rate/bit switching to match the native file.
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Let us know how can we improve this article!
Select atleast one of the reasons
Feedback sent
We appreciate your effort and will try to fix the article
