Follow the steps below to connect WiiM Mini to your WiFi network
  1. Connect WiiM device to your stereo system (Speaker/AVR/amplifier/Soundbar) through AUX OUT/Line Out (not AUX IN/Line in), SPDIF out or Coax(only for WiiM Pro). Plugin the USB cable into the Type-C power port.
  2. Download the free "WiiM Home" iOS or Android App from App Store or Google Play Store.
  3. Connect your mobile device to the 2.4G/5G Hz WiFi network (5 GHz preferred) that your WiiM device will be added to
  4. Open the "WiiM Home" App, click "Set up" and follow the in-app instructions, then connect WiiM device to your WiFi network.
Video tutorial
If you continue to run into to issues please check out this Help Article - Advanced troubleshooting to find your device.
